As the title states I'm going to be doing this swap this weekend since a pothole took out my oil pan and ruined my engine. Anyway I bought a low mileage engine out of a 96 EX coupe and I was curious as to know if I can still run my p28 ecu with this engine. A few people have told me that I would have to change my dizzy and fuel rail for this swap to work. Along with the alternator. Now that seems fairly reasonable. Only thing is that I sold my dizzy to a friend when his had crapped. Can I rewire the obd2 one to work. I have read that you can, just curious as to whether or not the time is worth it. Also are the timing belt and water pump the same? Just asking because I had replaced them literally 2 days before the pothole incident and if I could reuse them then I will.I'm confident in doing this swap just wanting to make sure I have everything I need prior to the dive. Any help would be appreciated. thanks in advance
