96 Gsr Into 92 Civic Hatch
Discussion in 'HYBRID -> EG-EK / DC' started by supersol93, Jan 27, 2003.
  1. supersol93
    supersol93 Member
    Southeastern, PA
    I was wondering what I would need to swap a 96 GSR motor into a 92 Civic VX. I have a 95 GSR ecu. I just need to know what wires I need to make this work. Thanks
  2. supersol93
    supersol93 Member
    Southeastern, PA
    Does anyone know how to make this work
  3. E_SolSi
    you are already wired for VTEC ... just use your harness ... you may need to add wires for the secondaries (or you could switch to a single runner intake like the skunk2 and forget the secondaries) and lengthen a few... thats about it
  4. onefastcivic
    onefastcivic Senior Member
    you will need to add a wire for the knock sensor lengthen the vtec wires and add the secondaries like e_solsi said but other than that use the vx harness and plug and play. oh and you will want to get a gsr shiftlinkage and axles too
  5. supersol93
    supersol93 Member
    Southeastern, PA
    I heard that the distributor and injectors on this motor will need to be changed in order for it to work. Is this true. My VX engine harness will just plug onto this motor with the exception of the knock sensor and secondary butterflies?
  6. supersol93
    supersol93 Member
    Southeastern, PA
    Are there any advantages to using the OBDII motor over the OBDI.
  7. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    No. OBD 2 is just abunch of emissions shit. I think it also has 2 o2 sensors.
  8. E_SolSi
    OBD-2 engine = newer, most likely has less miles
    OBD-1 engine = less restrictive ECU
  9. SolReaver
    SolReaver Senior Member
    run a obd1 ecu motor, use everything else obd2
