96 Integra rebuild
Goose503
Hey, so I'm new to all this, but I bought a 96 integra ls, 5 spd, and then got into an accident, so im in the process of rebuilding a new car. I bought a 94 integra shell, and have swapped engines, and all the interior, but Ive run into some trouble. The ecu from the 96 is an obd2 and the 94 a obd1...the wires dont match up, and i was wondering if it were possible to swap wiring harnesses, and if not, what the best way to go about fixing this problem is. Thanks.
Obd2 to obd1 jumper conversion harness rywire sells them if you google it I'm sure you will find a few different places to get it from.
no need for conversion harnesses
you can just plug the OBD-2 engine harness in to the OBD-1 chassis harness at the shock tower plugs
then run it off the OBD-1 ECU
easy as that
