Part Info Cam Gears Skunk2 Valve Springs Skunk2 Retainers Skunk2 Valve set Skunk2 Cam Shafts skunk2 ProSeries Stage 2 Intake Manifold Skunk2 Throttle Body 68mm Skunk2 Air Intake AEM SHORT RAM INTAKE vtec Valve Cover Royal Blue JDM Golden Eagle Conv Kit size = to piston size ECU P28 Chip s300 Conversion harness OBD2-OBD1 Rod Bolts ARP Distributor OBD2a Timing Belt Tensioner OEM Timing Belt integra Type R Water Pump OEM Oil Pump integra Type R Pistons overbore .25mm Head Studs ARP Header AHC6606 Exhaust System Catback SP2
Any suggestions, this will be a LS/vtec build on a 96 integra SE, this list doesnt include head and block work just parts list.
