96 ls into 94 gsr shell?
rktcivicef
is there any mods that has to be done to put a 96 ls into a 94 gsr shell? thanks for the help.
ok thanks just asking. i meant like anything to the harness since the gsr was vtec or small things like that. simple question
I don't remember if that is an OBD change or not. And you would have to change your ECU as well. I'm sure someone will pipe up and lead you in the right direction, but in the meantime, our reference section, as well as the search bar, will yield similar information.
