96 LS into 97 DX.
Discussion in 'HYBRID -> EG-EK / DC' started by korey, Mar 16, 2004.
  1. korey
    korey Senior Member
    OREGON
    I contacted Hasport and they said i need the following:
    EKSTK mount kit
    EKRB rear bracket
    EGBLINK shift linkage
    EGAC a/c bracket
    Is this right, would I need EG mount parts for my EK? Or am I just not thinking straight. Let me know, thanx.
  2. brian11to1
    brian11to1 Senior Member
    If HaSport said that's what you need, then thats what you need.
  3. katman
    katman Member
    PASADENA, CALIFORNIA
    you can use any of these B-series engine mounts to allow the LS motor to bolt into your EK:
    92-00 (jdm or us) B16 front tranny mount
    or
    94-01 integra (any model) front tranny mount
    92-00 (jdm or us) B16 A/C mount
    or
    94-01 integra (any model) A/C mount
    92-00 (jdm or us) B16 rear engine bracket
    or
    94-01 integra (any model) rear engine bracket
    or
    99-00 Si coupe rear engine bracket
    92-00 (jdm or us) B16 shift linkage (except dohc delsol)
    or
    94-01 integra (any model) shift linkage
    or
    99-00 Si coupe shift linkage
    For the timing belt mount, you'll have to change the LS (3-post) mount to a 2-post timing belt mount, as seen on a 99-00 Si coupe
    and lastly, you'd reuse your SOHC TOP tranny mount (its compatible with a hydro B-series tranny)
    If your LS motor comes with motor mounts & a shift linkage, your pretty much set.
  4. korey
    korey Senior Member
    OREGON
    Thats awesome info, thanx alot!
