BACKFROMS2K
Hey I'm trying to get some info about this swap, from what I've seen I can use either mounts but b series will work better as they are stronger and need Del Sol DOHC VTEC shift linkage or modify stock. but my main question is the Wiring Harness, I don't have the Engine Harness from the B18 but I do have the cars stock engine harness. Can I make the Stock engine harness work with this engine? I do have a OBD1 Jumper and a OBD1 chipped ECU with a stock LS map. All comments will be greatly appreciated.
