97 accord no fire h23a
Discussion in 'HYBRID -> BA-BB /CA-CD' started by h23aaccord101, Sep 21, 2011.
  1. h23aaccord101
    h23aaccord101 New Member
    i got a 97 accord with a h23a swap but is getting no fire. 1st question the cars converted to obd1 the engine harness is out of a 94 and has a jumper harness to a chip p28 so can you us the 94 harness in a 97. question 2. the ground running from transmition to frame after turning over a few times gets real hot just after a few seconds of turning the car over. the dizzy and all dizzy,coil,cap,button,plugs and wires are new and fuel pump kicks on so say main relays good unless its possable for the main relay to kick fuel pump on but not let gett any fire. thanks for the help
  2. h23aaccord101
    also the distributor has been coverted to internal coil and ive checked the plug for dizzy and hot wire for the coil and neather have power. the plug has a few grounds but no power
