97 accord swap....help plz
Discussion in 'Accord' started by accord97, Feb 17, 2010.
  1. accord97
    accord97 New Member
    whats up every1, i'm new to swapping....so i need a lil help.
    I have 97 accord LX and was thinking about putting a h22. I heard the h22 is the best
    and simplest swap.....is it true???? thanks
  2. BrutalB83
    Rochester Hills, MI
    What are your criteria for "best"? The H22 is a GOOD swap, and very easy, but there are obviously better motors out there...
  3. accord97
    accord97 New Member
    oh ok thanks. is the swap a straight bolt in on the h22? and can i use the same tranny from my non-vtec for the h22?
  4. BrutalB83
    Rochester Hills, MI
    Yes, and yes, although using an H22 tranny would result in better gear ratios...
  5. accord97
    accord97 New Member
    one more question, what h22 year or gen would you recommend for my accord 97???
  6. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Make sure you get an OBDII and not OBDI motor. It is all about compatibility between the engine, ECU, and wiring harness. You will save many headaches and lots of work/money by doing this. If you grab a 97+ Prelude engine You will be golden.
  7. accord97
    accord97 New Member
    oh ok thanks....you guys really helped me alot...^_^
