97 acura cl swap?
Discussion in 'Accord' started by blewup91rex, Oct 23, 2006.
  1. blewup91rex
    blewup91rex New Member
    I have a 97 acura 2.2 cl watever the engine code is i kno it 2.2 vtec and i wanna do an h22 wat do i need to start with
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    this is the exact same swap as the 94-97 accord. (someone correct me if im wrong) your going to need a complete swap from somewhere like h motorsonline. so motor, tranny, ecu, axles. wire in secondary butterflies. lengthen idle air control, o2 sensor and the front thermostat jacket sensor.
    your car since it already has vtec should not have to be wired in and also your car may have a knock sensor (presuming it does)
    you will also need to have an obd 2 to obd1 harness if you get an obd1 motor, which i do suggest.(im bias)
    driver side motor mount will need to be trimmer ever so slightly to make it fit.
    exhaust will need to be modified to fit the header if you keep the cat other wise you will need to just have a test pipe made.
    i believe there is a write up on this in a hybrid forum...not sure its been a long time since ive been around here.
    got any ?'s feel free to pm me.
    good luck
  3. honeycutt289
    honeycutt289 New Member
    will it bolt right or need fabrication
  4. Jared759
    Jared759 Well-Known Member VIP
    SC
    Yo tc this thread is 4 years old.
