Quoted post[/post]]
You have to use the a/c compressor bracket from a del sol that had the b16a3 in it or a crv's will work. The whole point of using those brackets is so that you can retain your d-series compressor.
38930-P54-000 BRACKET, COMPRESSOR $116.22Quoted post[/post]]
Quoted post[/post]]
SWEET!!! del sol with b16a3 ?? is that the 96-97 del sol SI ?? and anyone got the part number or real name for it, i tried searching on hondaautomotiveparts.com and could not seem to locate the bracket.
50827-S04-N10 BRACKET, RR. ENGINE MOUNTING $39.50Quoted post[/post]]
that sounds good...anyone got the part number for the SI mounts needed to swap in a GSR to a 2000 CIVC ??
Quoted post[/post]]
http://slhondaparts.com/search.asp?partNo=50827-S04-N10
99-00 Civic Si Rear bracket^
You really could be doing this yourself
