97 Civic EK Hatch / B18C Swap-Built Bottom End / $7,000
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by Vosty, Nov 6, 2006.
  1. Vosty
    Vosty "REP 4 U" Whore Member!!!
    Lower Valley, WA
    To make a long story short, Ive got a kid on the way and have to let loose of this partially completed project. I paid $6,500 for it in March of 06 and have put an additional $5,000 back into it already. My loss is definately your gain. It recently recieved its second b18c swap this time with a heavily built bottom end. "The asking price is $7,000 firm, no trades" Selling the car at this price puts me out $4,500+ dollars but it must go. *For an additional $500 I will leave the audiovox alarm system installed, and an Ingalls Front Ball Joint and the Ingalls Rear SmartArm™ Adjustable Link (Polyurethane) "for camber" uninstalled, and also throw in the MSD 6-AL ignition not installed... The Audiovox alarm is model # AX901, We also did a power door lock conversion, the only thing not installed on it is the remote start and turbo timer features, but all wires/box will be included...
    Edit: Im located in Prosser, WA area code 99350
    ▫Exterior▫
    ♦1997 Civic Hatchback DX.
    ♦It Has A 99/00 Front End Conversion.
    ♦Type R Front & Rear Lip Kit, Sideskirts Are Stock DX.
    ♦PIAA GT-X H.I.D bulb
    ▫Electronic's▫
    ♦Panasonic Head Unit
    ♦Pioneer 6x9
    ♦Si Gauge Cluster
    ♦*Optional-Audiovox AX901 2-way remote start w/ command confirm.*Read above...
    ▫Performance▫
    ♦Built B18C1 "Under 200 miles"
    ♦Stock head "loosing a lil compression" needs to be addressed.
    ♦Golden Eagle Sleeves (81.5mm bore)
    ♦Wiseco Coated Pistons (9.5:1)
    ♦Eagle H-Beam Rods.
    ♦ACL Bearings.
    ♦Whole Bottom End Plastigauged.
    ♦Golden Eagle Head Studs.
    ♦Skunk2 Intake Manifold.
    ♦*MSD 6-AL Ignition. "Not Installed, read above"*
    ♦Ebay Cold Air Intake
    ♦AEM Fuel Dist.
    ♦3" Mandrel Exhaust By "www.linderpowersystems.com"
    ♦3" Magnaflow Muffler. "Actually Prty quite considering 3"
    ♦3" Megan Racing: Test pipe/resonator.
    ♦p28 Chipped ECU / VTEC @ 4800 rpm's - 8200 Redline
    ♦New oem timing belt
    ♦New oem Water pump
    ♦New Exedy Organic Clutch "Under 200 Miles"
    ♦New ACT Chromoly Flywheel "Under 200 Miles"
    ♦NRG Torque Dampner
    ♦Im sure im missing something
    ▫Suspension▫
    ♦Cheap Ebay Coilover's?
    ♦15" Rota Slipstreams
    ♦Toyo Proxes 4
    ♦Si Brake Master Cylinder
    ♦SS Brake Lines "Put on 200 miles ago"
    ♦Si Front & Rear Brake Conversion
    ____________________________________________________________
    The Good:
    .Fully built engine that can handle 500+ HP. Once the head work is addressed and fixed I would do it myself and sale the car for $8,500 but I dont have time to be waisting towards this project due to the baby bieng here in the next month and a half...
    .Under 200 miles on the new B18C1, since the build. "Took old B18C out"
    .Everything in the engine is brand new, I spent $4,000 just in parts + engine cost building it. Sleeves done in California by Golden Eagle"
    .I have a carfax from the day I purchased the vehicle and can email the carfax to you. "The only thing that will possibly show up is that the Gauge cluster has been swapt to the SI cluster and Im not sure how it will show up on the carfax."
    .Flawless Rota Slipstreams 0 scrapes/scratches. And lot's of tread left...
    .It has kickass rain-x windshield wipers FTW!!!
    The Bad:
    .The current head is loosing a lil compression. Needs to be addressed, either repaired or replaced.
    .Stock shocks need replacement.
    .Would recommend replacing ECU with either a P72 OBD1 or the Hondata s300. I was going to put in the s300...
    .Rear 1/4 panel dent as seen in the pictures.
    .Front right fender has dents in it...
    .5th gear synchros is out, it grinds... all other gears flawless...
    .Some paint scratches on front & Back Bumper...
    _____________________________________________________________
    Below is a list of things I had planned to do this winter/spring, "None of the parts listed below come with the car" and havent purchased any of these items...
    My old Build Plan's to finnish this project...
    ♦Hondata s300
    ♦Turbo Kit By Linder Power Systems
    ♦Wideband 02
    ♦Paint & Body Work
    ♦Fully Adjustable Coilovers, shocks
    ♦F&R Sway Bars, Strut Bar
    ♦Replace GSR Tranny w/ Type R LSD Tranny
    ▫Pix▫
    ▫I have a lot of images of the car so if you want a certain side or anything let me know...
    Thanx,
    Chad
    PM or phone me @ (509) 439-9428
  2. eg6sir
    seen this in your myspace bulletin.. sux you gotta sell it..
  3. Vosty
    Lower Valley, WA
    Ya I will find another project down the road its all good... the tacoma and corolla are paid for, kinda want to get rid of any bills to prepare for the baby's needs...
  4. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    If I had 7k around, and lives on the left coast, I'd def pick that up. Bump for you man.
