97 Civic Ex Coupe
Discussion in 'HYBRID -> EG-EK / DC' started by Fo Sho Pros, Mar 4, 2003.
  1. Fo Sho Pros
    Fo Sho Pros Junior Member
    I was just wondering if the b16a2 would bolt right in to replace the stock d16....and how much would i expect to pay for the swap, i found the motor for $2350(complete changeover) on www.hmotorsonline.com
    also(off the engine topic but oh well) if i bought the 99-00 si headlights and a hood, front bumper, and fenders to fit to it, would that all bolt right on?.......and im assuming that the 99-00 stock half and half taillights will bolt right in on a 97, correct me if im wrong
    Thanks alot, and give me any comments or suggestions
    -Ryan
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The B16A2,with slight wiring will do good in there,easy.
  3. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    I know the tailights will bolt right up cuz one of friends did that. He had a 96 coupe and he put 99 Si tailights on it.
    Good luck with the swap and the whole headlight project.
  4. Tonyd0821
    Tonyd0821 Banned
    hey u from so cali?
  5. Zerosk8r455
    Zerosk8r455 Senior Member
    San Diego, CA
    Man..a b16a2 for 2350? a bit much...live near SD? i can help you find one for much cheaper..complete motor for under 1.8k..if you live in or near SD..please feel free to I/M me..i'm willing to help out anyone in the near area..i hate seeing people get ripped off..i don't personally sell these motors so don't worry about me trying to make a "pretty penny" off you...i just have friends who have connections directly with the sellers..this way the middle man is cut out..thus saving you oodles and oodles of $.
  6. Tonyd0821
    Tonyd0821 Banned
    yooooooo
    im in so cali, bout 2 hours from sd...can u get a b6a2 with low miles and receipts for 1.8k?
    holla
  7. Fo Sho Pros
    I'm from Richmond, VA. Not much to see out here, theres a few people with motors around. Most of the people around here are doing show stuff, like my friend who lives across the street put R33 Skyline Tail lights in his civic, i will post some pics if you guys want to see it, they are pretty clean....I want a motor before i do anything though.....just get that all done and then work on show.....but yea im in Richmond so I dont know how cheap I could find it here, does anyone know about how much it would cost for installation, since i guess its just some extra wiring or so.....
    Thanks,
    - Ryan
  8. xj0hnx
    C.C.TX.
    Check the salvage yards in your area,before you rush and buy a motor from a place on line.
  9. ekPhred
    ekPhred Senior Member
    yea, if you want to put all of the 99 spec civic stuff in there. you can, you have to buy all of it to put it on though. the taillights will bolt on no problem. if you're going to get the whole 99 front end, you'll be fine. you can probably bolt the 99 spec on your civic. but i believe the grills from the 99-00 to the 96-98's are different. the 99 specs is a little wider as opposed to the 96-98 ek's.
    so it will bolt right up if you buy all the parts like you said. the only difference with the 96-98 to 99-00 is the front end. the rest is the same, and the taillights of course. good luck. :p
  10. Fo Sho Pros
    My friend told me there is a warehouse in northern VA that has them for $1300, dont know what you get with it though, ill just have to check it out, thanks for the help
    -Ryan
  11. B16
    B16 Super Moderator VIP
    yay area, CA
    i belive you'll need the front radiator support from a 99si as well.
  12. ekPhred
    yes, you will need the radiator support as well, forgot to point that out... :D
