97 civic lx idle issue!
Discussion in 'General Tech and Maintenance' started by xpdude, Jun 3, 2009.
  1. xpdude
    xpdude New Member
    elgin
    the idle reves up and down as it warms up. i tried to swap the iac but it does the same thing again. i understand you can clean them? how do you do this?
  2. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    it sounds like your tps sensor is bad,check that first...
  3. superturbohatch
    superturbohatch New Member
    i had that problem once,,,,ended up being air in the coolant,,,there is a valve to bleed the air located by the thermostat somewhere.
    are you throwing any codes?
  4. xpdude
    xpdude New Member
    elgin
    idle issue cont
    i am not throwing ne codes. i can unplug everything from the throtle body but the iac and it will shake and idle rich. i am attempting to clean the iac the sensor w/ 2 small coolent lines running to it? i am gona clean the throtle body. how do u remove the tps?
  5. xpdude
    xpdude New Member
    elgin
    trans issue also!
    its a crapomatic 4spd b4ra. slips in 1st then reves into 2nd and shifts fine, its overfilled too. i corrected the level, same thing. i hear you HAVE to run honda fluid in these? can the irradic idle cause this?
  6. xpdude
    xpdude New Member
    elgin
    idle issue fixed!
    i had to spray a crapload of starting fluid into the valve and tb and scrub away w. a toothbrush!
