97 civic lx with 91 ls motor swap
Discussion in 'ECU's, Electronics, and Tuning' started by ronnienewton, Dec 26, 2002.
  1. ronnienewton
    ronnienewton Junior Member
    My boyfriend is putting a 91' ls motor into my 97 civic lx. The lx started out as an automatic but we are making it a 5 speed. I read that we can just cut a few wires from ecu and use that. We also have an obd 0 ecu would this be better? If so what all needs to be done? What would need to be done for the stock ecu?
  2. brc80
    brc80 Senior Member
    Southern California
    I belive 91's are obd0 but please correct me if im wrong
  3. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    This is next to impossible without a LOT of time and VERY GOOD technical skills. This is an OBD0 into OBD2 swap--it's very tricky to jump 2 OBD gens in a swap.
  4. E_SolSi
    you will need to swap out the entire cars wiring harness or try to make your own crossover cable to convert the car to OBD-0 seeing that there is pretty much no way to make an OBD-0 engine run OBD-2... and the harness/ECUs are not compatible
    and in most places what you want to do is illegal.... engines must be of the same year or newer than the car they are being swapped into
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah your gonna have a fuck of a time running that, besides the obd2 to 0 conversion also the cable clutch conversion.
  6. ronnienewton
    I was able to convert the motor from obd0 to obd2 and continued to use the stock automatic ecu. I took the car to the local 1/8th mile track and ran 9.70's with s1 tranny with an lsd. The car was then totaled the next day due to a bitch running a stop sign. We know have a 95 v6 accord.
