97 del sol s w/ b swap problems
Discussion in 'Civic and del Sol - EG and EK' started by supastardavid, Sep 6, 2009.
  1. supastardavid
    supastardavid New Member
    My del originally came with a d but a b was swapped in. Ever since the b20 was swapped in it never ran right. At first it was running sluggish when full throttled. Now my bro's friend changed up some wiring and it doesnt run sluggish anymore, but it is running rich and only get 125 mile to the tank. I'm not sure what to do and which wire was changed. Any help at this time would be greatful.
  2. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    are you running the correct ecu/tune
  3. supastardavid
  4. jr018
    jr018 New Member
    I beleive you need to be running the ecu for the engine you have or similar.
    1 person likes this.
  5. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Yes ^^^ Need an ECU for the motor. A OBD2 P75 is a direct fit and not too expensive.
  6. supastardavid
    I am currently running the obd2 p75.
  7. CAFROG
    NOR-CAL
    Okay....your previous post made it seem like you were running the original ECU for your car.....
    P75 OBD2 is a 96-up Integra LS B18B
    Oops....I forgot to ask....your Del Sol is OBD2? Year?
  8. supastardavid
    Sorry I should have been more clear. The car is a 97(obd2), when motor was first swapped it had a bog, then my bro had a friend in Orlando fix the box but now runs way to rich. I am currently in Mississippi and my bro cannot get a hold of the guy that worked on the car. I searched how to swap a b series into a del sol but could not find anything.
  9. CAFROG
    NOR-CAL
    Its a straight forward swap then (in general). You may have an issue that is not related to the swap. What did your Bro "Fix"? Find out what he did.
  10. supastardavid
    He said something about swapping some wires to keep the fuel pump from pushing too much gas. It's been over 5 years and doesn't remember which wire.
  11. CAFROG
    NOR-CAL
    No wires should have been swapped! (at least to the best of my knowledge).
    EVERY plug on your Del Sol harness should have hooked up to the B20 longblock.
  12. matt70
    matt70 New Member
    thinking of doing a swap on my civic lately
  13. E_SolSi
    awesome...
    thanks for sharing...
    now give it a little more thought...
    come up with some ideas and or questions...
    then find the proper section...
    click the "new thread" button and create your own thread...
  14. cj_89
    cj_89 New Member
    lmao!!!!
  15. RickParker
    RickParker New Member
    Shippensburg, PA
    :lol: :werd:
