97 Ek W/ B16a
Discussion in 'ECU's, Electronics, and Tuning' started by WannabeSI, Jan 2, 2003.
  1. WannabeSI
    WannabeSI Senior Member
    I have a 97 civic coupe that has an obd2 b16a in it. I was wondering what would be the best ecu for this setup? Should i run the jdm ecu that came with it? or also i have a 99-00 civic si ecu but i think they are obd2b or should I purchase a 96-98 GSR or Delsol ecu? What would perform best? Please help me out on this one.
    Thanks
    Rick
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    If it is an OBD2a, then 96-97 del Sol VTEC should do the trick. The JDM ECU you have will also work, but it may have a 112 mph speed limiter (not sure if that carried all the way to OBD2).
  3. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    P2T 99-00 us Si ecu.. you'll need a jumper harness so you can run a obd2b ecu
