FL 97 integra.fully built b20.rota.nardi.NEW PAINT.function 7.function & form etc!
stacksondeck
BRAND NEW PAINT JOB !! not even a week old
2 Stage Base coat / Clear coat MIDNIGHT BLUE
VIS carbon fiber hood
Type r Lip
Edm rear fog
Benen Industries Tow hooks (front & rear)
Jdm/Oem integra window visors
8,000k H.I.D.s
Egr Rear Visor
98-01 Tail lights
98-01 rear bumper
Edm/Oem clear Sidemarkers
Edm Honda integra badges
Oem Mudflaps
98-01 Side Mirrors
Sunroof works perfect
---Motor---
NON VTEC
B20b with less than 1000 miles on it
Head is built
Mild Port and polish
3 Angle valve job
Crower dual valve springs
Crower titanium retainers
Crower Stage 2 cams
Skunk 2 Cam gears
Fresh GSR Transmission (no grinds at all, smooth like butter)
Brand new Slave Cylinder
All polyurethane bushings
Act stage 2, 6puck
Block was hot tanked
Conversion harness to obd1
Chipped obd1 P75 with Hondata S300
New spark plugs
Skunk 2 Intake manifold
Skunk 2 70mm throttle body
Hondata Intake Manifold Gasket
Password Jdm carbon fiber whale penis intake
Hasport mounts
J窶冱 racing torque damper
8lb ACT flywheel
-Built bottom end-
11:5:1 Super-Tech Pistons
New Piston Rings
Eagle H beam Rods
ARP Rod Bolts
ARP Head Studs
Golden Eagle Block Guard
Brand new ACL rod/main bearings
Crank has been balanced
Brand new Thrust washers
Brand new Water Pump
Brand new Timing Belt
Brand new Oil Pump
Rc 310 cc injectors
Dc sports fuel rail
B&m fuel pressure regulator
Vision Fuel pressure gauge
Hasport Stage 2 Axles
Has Cold A/C
All the wires have been tucked
---Interior---
Very Clean
Fresh Gsr leathers (front & rear)
Fresh gsr door panels
07 s.i. Shift knob
Integra type R pedals
Type r shift boot
Type r arm rest delete
Type r air bag delete
Type r cluster
T view double din tv w/ DVD player
Nardi Black Suade Steering wheel
Rockford Fosgate 3way speakers all around
Apexi Vafc2
AEM Wideband gauge
C-pillar tie bar
Black Carpet
Cobra radar
Power windows
Power locks
Power mirrors
Viper 2-way Alarm
Hood sensor
---Wheels/suspension---
Brand New Steering Rack
Polyurethane bushings
New Brembo Slotted rotors
Hawk brake pads
Good Ridge Stainless Steel Brake Lines All around
Function over form type2 full coilovers 18 way adjustable
Rota j-mags GOLD 4x100 15x7 +35 offest
Brand New Falken 912 tires 205/50/15
Front and rear strut bar
Beaks lower tie bar
ASR Rear Subframe Brace
Function 7 rear lower control arms
Vision lug nuts
Blox Extended studs
thats what i can think of now might be missing one or 2 things but dont come to mind right now . THE CAR IS ALSO REBUILT TITLE DUE TO THEFT RECOVERY
SERIOUS BUYERS ONLY !!! CAR IS SUPER CLEAN IN AND OUT SO IF YOU GOT MONEY THEN WE TALK IM NOT HERE TO WASTE MY TIME OR YOURS . MORE PICS UPON REQUEST
$5500 FIRM! THERES MORE THEN THAT IN THE CAR I JUST NEED IT GONE ASAP!
305-613-6725 IF I DONT PICK UP TEXT ME
more pics upon request?? you'd have to post some up for there to be more.. on that note.. ttiwwop
