97 nissan p/u
Discussion in 'Other Vehicle Discussions' started by 9inch, Nov 30, 2004.
  1. 9inch
    9inch Member
    Omaha, NE
    somethings going on with my daily driver. when i'm driving in the lower gears 1 st 2nd and 3rd i get a jerky feeling in the low rpm's. it's almost like the truck wants to die on me. then as it gets up to about 3000 rpm's it runs fine. until i shift again, then it jerks until i get up to 3000 rpm's. i'm not sure what the problem is. i had my fuel injectors cleaned last time it was in the shop. i thought maybe the clutch was going bad or something. any info would be great because i would like to fix the problem myself.
  2. TurboMirage
    fuel filter?
  3. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    sounds fuel related... maybe fuel pump... maybe spark... I think I am complete guessing on this
  4. 9inch
    9inch Member
    Omaha, NE
    if it is the fuel pump is there any way for me to check it? what can i do to locate the problem?
