97 prelude sh doing full exhaust
95silverprelude
Hello everyone, I have kind of waited to last moment to check this but, I am doin a full exhaust on my 97 prelude sh, tri-y headers, full 2.5 inch tubing, 20 inch resonator, no cat, and magniflow muffler. I have heard rumors that running different headers messes with the first 02 sensor, is this true? On the other hand I know that running it catless is going to mess with the secondary 02, but I will eventually be getting the ecu chipped. Anyone know the details about this.
Thanks
It just depends on whether the header has provisions for the O2 sensor. On my 97 Integra the header had an O2 bung welded in. I just plugged it in and it works fine.
I still have a cat though. You're right, if you eliminate the cat then you're going to get a CEL for the secondary O2 sensor...
Ok finsished the exhaust last night started it up and the cel light is on, I know why. My ATTS light is on as well, I didnt know the ATTS had anything to do with the o2 sensor or vise versa. I ran into a snag with the placement of the first o2 sensor, (02 sensor bung in header was right behind the crossmember) so I ran in it the second spot where I welded a bung in (after the flex pipe). The secondary o2 I dont have plugged in at the moment. Any ideas on why my ATTS light is on?
Thanks
