97 sohc mounts
puddin97coupe
i am puting a sohc in my car and i need the stock rear trans mount and the mount on the drivers side that is on the block i think ! the motor cam out of a obd1 car and i am putting it in a obd 2 car so i am useing a obd2 harness ex i got a jumper harness for obd2a to obd 1 and made a jummper for the dizzy just need to fig out the mounts i need to use any clues let me know
why?
just get a obd2 d16 and save you all the trouble of wiring up the distributor and other common sensors. all d16 cost just about the same, actually I usually find the obd2 cost less.
truthfully, I don't see why the obd1 d16 doesn't just bolt in the obd2 d16... they don't match up?
