98 Accord.....Head Gasket Replacement
Discussion in 'Accord' started by JDMchic, May 12, 2010.
  1. JDMchic
    JDMchic New Member
    New York
    So I have a 98 Accord and the head gasket is leaking. *NO Oil/Coolant mix...Coolant just going out the exhaust** The kit Im buying includes :
    2 head gaskets, 2 valve cover gaskets, 2 intake manifold gaskets, 2 exhaust manifold gaskets, 2 exhaust pipe gaskets, 2 soft gaskets, 10 cover bolt gaskets, 24 valve stem seals, 6 rubber seals, 2 oil seals, 6 spark plug seals, and 2 upper intake manifolds
    Since the engine will be out, I figured I'd maintain it and have the water pump and timing belt done too. Any other suggestions?
  2. JDMchic
    JDMchic New Member
    New York
    Oh yea...V6
  3. BrutalB83
    Rochester Hills, MI
    Sounds like you've got all the basics covered pretty well... :thumbsup:
  4. JDMchic
    JDMchic New Member
    New York
    Yea...I've been putting it off for a few weeks and its starting to get worse...so gotta do it ASAP
  5. Magana559
    Magana559 The Warden
    fresno Ca
    get a 3 angle valve job.
  6. egb19c
    egb19c New Member
    While you have it apart get the heads pressure checked just to make sure. It would suck to put it all back together and find a head was cracked :eek:
  7. JDMchic
    JDMchic New Member
    New York
    Thanks...I'll make sure its done before putting it back together.....Also, will a head gasket issue effect the car from starting properly...Basically, the car is fine at initial start but say I go to the store when I try to restart the car it takes forever to kick over and runs poorly
  8. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Yeah it sounds like while it is hot the cooling system is under pressure and leaking coolant into the cylinders, retarding startup. This is especially the case if the exhaust is blowing white smoke on startup.
  9. JDMchic
    JDMchic New Member
    New York
    Anyway to ease the issue until I can get it done? If I open the radiator cap and add a little more coolant its starts up again fine. I guess...im releaving the pressure????
  10. f22b1 coupe
    Indiana
  11. JDMchic
    JDMchic New Member
    New York
    On good start ups theres no white smoke, no "head gasket" smell and it runs very good. On that retarded start up...white smoke, stinks and drives like crap. As of last night its now starting to hesitate going into second gear. Can the gasket issue effect the tranny?
  12. f22b1 coupe
    Indiana
    Could be related to the heat, but most probably just because those trannies (V6) were FAMOUSLY weak and went out early. Change the fluid and see if the magnetic plug is covered with shavings when you pull it, and see if the fluid is burnt. You may have a tranny issue lingering.
