98 civic hatch front break problems
Discussion in 'Civic and del Sol - EG and EK' started by efcivic4dr, Mar 19, 2009.
  1. efcivic4dr
    efcivic4dr New Member
    cedar rapids, iowa
    I seem to be loosing all my break fluid at a steady rate. There is barely any pressure when i push the break pedal. When i do push the break, it pulls to the right side and often starts to shake the car. When the car is off and i push the pedal pressure will build but not last. I have checked the lines and have no leaks. Someone said the calipers may have gone bad on both sides? I personaly hate break but can not afford to take it in right now to get them fixed so. I need some suggestions. thanks
    -Carl-
  2. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    if it pulls to the right then its either your right caliper or a leak going to the left caliper
  3. serrilion
    serrilion In my own little world! VIP
    Vermont
    Dito above. You could go to a scrap yard... mite be cheap and maybe a little better
