98 ex coupe b16b swap ecu jumper help?
Discussion in 'HYBRID -> EG-EK / DC' started by rustyshackleford, Nov 3, 2013.
  1. rustyshackleford
    rustyshackleford New Member
    i just got a 98 civic ex coupe with a 00 civic ek9 type-r b16b swap on a trade and the guy i got it off of pulled one of the wires out of the ecu jumper harness and replaced it with a thicker one in doing so he drilled a hole for the bigger wire in the jumper harness on the side away from the ecu ....so i just want to get a new jumer harness but i don't know what one to buy?:confused: heres my ecu # if that helps 37820-pct-jll 1178-108190 keihin corp 1c also a little ifo on what i got here would be cool :D thanks!
  2. E_SolSi
    the PCT is a 96-01 JDM ITR/CTR ECU... could be OBD2A or OBD2B depending on what year it is actually from
    : Rywire
    you most likely need an OBD2A (car side) -> OBD2B (ECU side) conversion harness
    RyWire has them and come highly recommended
    double check with the image above to verify your connectors before ordering anything though
