GS-R Del Sol
i just dropped a 98 gs-r motor in a 97 del sol, did the mounts, axles brakes all off of gs-r, linkage, all i have to do now is the harness, i have a gs-r harness, and i have my del sol si harness (D16Y8 SOHC VTEC), which harness should i use and what wires do i have to run to the ecu, and do i run 'em from ecu to the engine or just the conector, also should i convert it to obd 1? I have a harness to convert the ecu to OBD 1, or do i need one for a distributor like when doing OBD 0 to OBD 1, thanks
