98 GSR motor to a 92 Civic
Discussion in 'ECU's, Electronics, and Tuning' started by wernickt, Jun 16, 2005.
Thread Status:
Not open for further replies.
  1. wernickt
    wernickt Junior Member
    ok, to start. This is really a 91 JDM civic, but it's the same body as the 92-95 Civic. Second, the motor is from my wrecked 98 integra gsr. I'm tryin to figure out what all I need to get my swap done. The thing I'm stuck on now is the ECU.
    I'd like to know if I can just use the OBD2 ECU from the integra or do I have to buy an OBD1 ECU?
    If I get the OBD1 ECU, what all do I have to do to get it to work with the motor?
    If I keep the OBD2 ECU from the integra, what do I have to do to get it to run the motor in the 92-95 civic?
    I know that if I get the OBD1 ECU, I have more options in power upgrades from ECU work.
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    get a obd2 - obd1 conversion harness and run a obd1 ECU
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Please refer to our FAQ. There is no need to post your topic more than once.
    This topic has been closed by a moderator. Please continue your question in the other thread that you started.
    Thanks, Moderating Team
    :locked2:
  4. xj0hnx
    C.C.TX.
    Car should be OBD I, you gots it backwards y0
Thread Status:
