smoothekang
I recently changed my transmission and I lined up my torque converter onto my plate against the engine block, then I put the transmission shaft into the torque converter and as i try to line it into place i couldnt put the tranny together all the way face to face with block and tranny. So i put the bolt into the slot and decided to tightened the bolt to suck in the difference of a .25 inch gap. and in the end i heard a bite which closed up the gap between the tranny and block. My question is did I screw something up when I tried to close the gap by using force? Any information would be appreciated.
Thanks,
smnmoothekang
Thanks,
smnmoothekang
