98 honda civic electric wiring shorts
Discussion in 'Civic and del Sol - EG and EK' started by bwerth, Nov 27, 2012.
  1. bwerth
    bwerth New Member
    When I drive down the road my head lights and dash lights flicker and I can guess its a short of some kind but I don't even know where to start looking.
  2. Matts96HB
    Matts96HB . Moderator VIP
    Flickering? Can you be a little more descriptive?
    At first glance this seems like it could be something simple - maybe a bad/loose ground or connection. Does the car only do it while running? If so, could be an indication of an alternator on the way out.
  3. 99sidude
    Ohio
  4. 99sidude
    Ohio
    Stary by checking every single grounding point. There are a few under the dash and under the hood.
  5. bwerth
    bwerth New Member
    I will have to look for the ones under the dash. When I am going down the road they dim even more than what the dim lights are and it flickers between that and the normal level of brightness. Not just headlights but dash lights as well.
  6. dc4dude
    dc4dude Member
    chicago, il
    Hey, before you go chasing shorts and grounds, what's the voltage out of the alternator? At the battery? At the head lights? At your dash lights and at the fuse box?
