98 so coupe b20 noises
Discussion in 'HYBRID -> EG-EK / DC' started by j_mullet, Jun 26, 2014.
  1. j_mullet
    j_mullet New Member
    I have inherited a friends project car. As the title states its a b20b b18b heads, Crower stage 2 cams, skunk2 throttle body and intake manifold. The cat has been gutted with a greddy cat back exhaust. Gsr exhaust manifold and an eBay ecu chipped with knowing what the mods were.
    The problem is a rattle from 3500-4000 rpm. All heat shields have been removed. It almost sounds like header or valve train to me.
    Is it possible that a crank bearing could cause this? Kind of lost on this one not sure what it would be for sure.
  2. Briansol
    Did you do valve springs/retainers when you did the cams too?
  3. j_mullet
    j_mullet New Member
    From what I was told the springs have been done. But this is second hand info from the person that gave me the car. I thought that maybe it was the valves "floating" buy this goes away as the rpms get higher. I would imagine this problem would get worse as the rpms increase...not sure thought.
  4. Briansol
    was the bottom end done at all? forged pistons can sometimes be noisey.
  5. j_mullet
    j_mullet New Member
    Stock bottom end. I was planning to add zex in the near future. With this noise though it makes me nervous to do so.
  6. Briansol
    Yeah, i'd hold off until you figure it out.
    Kinda hard to diagnose over the internet...
