98civic Disc brake swap
Discussion in 'Wheels / Suspension / Tires / Brakes' started by slammincivic, Jun 24, 2003.
  1. slammincivic
    slammincivic Junior Member
    I've got a 98 civic lx with rear drums. I wanna get disc brakes in the rear, I've heard you can pull the disc brakes off of an EX but I dunno what I need. Can anyone help?
    thanx in advance
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    get the whole rear trailing arm assembly, has the roter and caliper already attached to it, make sure it has the ebrake cables as well.
  3. randerson165
    randerson165 Senior Member
    Eugene, Oregon
    I have a 99 Civic EX and it has drums in the back.
  4. Baker
    Baker Senior Member
    Schaumburg, IL
    ex's don't have rear disc, only SI's do or you can use integra rear parts
  5. slammincivic
    I thought 6gen civic ex had optional rear discs?
    Anyway what year/gen teg should I get the rear trailing arm assembly from?
  6. WiggerMan
    WiggerMan Member
    I wanted to do this same thing and I was planning on needing SI trailing arms but has anyone seen or heard of a successful x-fer from a intergra to a civic on the trailing arms? that would save me from needing to find a SI trailing arm... cause I was already getting a wrecked teg to do my swap from and this would help a ton if it works.
    Thanks
  7. B16
    yay area, CA
    94-01 integra yes
  8. halcyon985
    halcyon985 Senior Member
    Philly PA
    I can say for sure that a 00 ex comes with the option of 4 wheel discs. That package is without abs and only a manual tranny.
