98ek hatch b16swap
Discussion in 'Civic and del Sol - EG and EK' started by jay252, Oct 16, 2014.
  1. jay252
    jay252 New Member
    I got a idle issue but when I plug my 37820_p2n_a22 ecu in it sounds better should I be running that ecu on a b16? It plugs right in but the other ecu I need the harness for with v tech is a 37820_p28_a02
  2. Briansol
    the p2n is from an obd2a HX. it will NOT have proper fuel maps for a b16.
    the p28 is from an obd1 ex/si. it too will NOT have proper fuel maps for a b16 unless it's been chipped to have them
    There is no H or a space in the term VTEC.
    If you don't have emissions in your area, running the p28 chipped to p30 specs (the oem b16 ecu) with the conversion harness is the way to go.
  3. jay252
    jay252 New Member
    Ok thanks man appreciate the advice
  4. jason eden
    jason eden New Member
    H
    how do I makey own post ?? Thanks
  5. Briansol
    go to the main category list, and in the top right corner, there is a Post New Thread icon in blue
