99 b16a2 engine codes??
woo
I have a 97 ex coupe with a 99b16a2 that I swapped in but I have some codes
20-electrical load detector - does anyone know about this??
63-2nd o2 low or high voltage or slow response- any ideas?(I did remove my cat)
91-evap , fuel tank pressure sensor low or high input-
should I try fixing these , or should I just get a p30 obd1 ecu?
any Ideas are greatly appreciated!!
what ecu are you running?
if you ran the b16's ecu, did you get a proper wire conversion harness to plug it in to your car? your car is obd2a, the ecu is obd2b. there are wiring differences.
I used the b16 ecu and engine harness , but for the body harness all I had to go with were a few schematics and a multimeter.so I connected the body harness wires to the corresponding wires off of the ecu. I think maybe that the ecu wants to see some components that the car doesn't have.
well, #20 is the only 1 i'd worry about. i don't really know what it is to be quite honest.
2nd o2... obd1 cars have 1 o2, obd2 have 2. if you don't have a 2nd o2 sensor plugged in AFTER the cat, it will throw that code.
evap = emissions shit.
I do have the 2nd o2 hooked up , I wonder if I wired it wrong at the ecu.
I'll have to go to honda and ask about the e.l.d.
Thanks for the help!
