I just need to know if a newer (99) b16a2 will run right with an older b16 OBD 1 ecu. I want to keep wiring issues to a minimum and I guess this is the easiest way. But I want to know what wires need to be run to make it work. I was told the newer engines had knock sensors and the older ones didnt. So what new wires would need to be run, and will the OBD 1 ecu even work with the newer b16??
