99 B16a2 into a 96 EK coupe.
Discussion in 'HYBRID -> EG-EK / DC' started by namoper, Jul 29, 2008.
  1. namoper
    namoper New Member
    Ok I have just swapped a 99 b16a2 out of an EM1 into a 96 ek coupe. The coupe had the d16y7 in it. The problem I am having is the ecu from the em1 had one extra gray plug that does not seem to be in the harness in the 96 coupe. I was wondering if it needs a conversion harness but both cars should be obd2 as far as I know. I am new to this so any help on this would be great. I can post pics of the plugs if needed.
    Thanks in advance.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the 96 is a obd2a the 99 is a obd2b the ecu ports are gonna be different
  3. namoper
    namoper New Member
    So can I just get a harness to convert it over or do I need to get another ecu for it.
  4. thetunersource
    thetunersource New Member
    which ecu are you using?
  5. namoper
    namoper New Member
    Its the stock ecu out of the EM1. Not sure what the number is.
  6. 1dmty
    1dmty New Member
    what you need is a jumper harness. I'd stick with your stock ecu and get it chipped. But its all you man, just giving you my opinion.
  7. namoper
    namoper New Member
    where would I get the jumper harness. I just want to get it sorted and back on the road.
  8. ilubmyEG
    ilubmyEG New Member
    Utahrded, united states
    your going to want to get a obd2b to OBD1 jumper harness if your wanting to chip your car. OBD2 ecus cannot be chipped or reprogrammed.
  9. namoper
    namoper New Member
    Ok so if I get a p28 ecu thats chipped and a conversion harness I should be sorted at that point. There is no near by me as I am in the UK who chips ecu's so I will have to buy one allready done. Can anyone sugest a good place to get one in the USA. Thanks
  10. ilubmyEG
    ilubmyEG New Member
    Are you running just a stock b16a2? If so, it would be pretty easy to get that :) chipped or virgin ecu.
  11. namoper
    namoper New Member
    yea its a stock b16a2. But no body in the uk chips ecu's that isn't charging an arm and a leg. Its cheaper to get one from the usa and ship it here. Just need to know where.
