'99 b16a2 into a 97 cx civic
Discussion in 'HYBRID -> EG-EK / DC' started by B16_EK, Mar 15, 2007.
  1. B16_EK
    B16_EK New Member
    My first post yes... Hello everyone!
    Ok, I searched and searched found a lot of answers , but now I'm really messed up lol
    Here we go...
    I have my stock cx wiring harness (no vtec)
    I want to get a p28 ecu (get it chipped)
    I want to get a obd2a to obd1 conversion harness
    Now, from what I understand, I need to plug all that together and ...
    • pass my vtec wire from the ECU to the Solenoid
    • pass a wire from the ecu to the knock sensor
    Where I'm not sure.. is what do I do with the IACV wiring ? From 3 pin to 2 pin ?
    Please correct me if I'm wrong anywhere ! First time doing the swap and I don't want to go wrong anywhere.
    Thanks a ton!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yours are both obd2 you need to convert from odb2a, to obd2b
  3. B16_EK
    B16_EK New Member
    Thanks for the reply,
    Yeah I'm aware that both are obd2 , but an obd1 ecu(the p28) is perfect with a chip(from skunk2) . Which is why I want to make the obd1 conversion.
    From the obd1 ecu I'm not sure what I need to do with the wiring (vtec / knock sensor / IACV )
