99 Civic EX with B18B
Discussion in 'HYBRID -> EG-EK / DC' started by Tim@Canspeed.com, May 29, 2005.
  1. Tim@Canspeed.com
    Tim@Canspeed.com Member
    As the title says. We have a 99 Honda Civic Si (Canadian) with an OBDII B18B. Should the stock ECU start this engine or more importantly be compatible with the Integra distributor?
  2. PhyRe
    PhyRe Senior Member
    ct
    it will run like crap fallin down the stairs
  3. Tim@Canspeed.com
    I'll answer my own question as we did figure out the problem. Yes, indeed the Civic Ex (Canadian Si) ecu started and ran the B18B. The reason it wasn't starting before was due to the valve adjustment from the engine machinist. The valve lash was way out of wack and the valves were not closing. A quick compression test revealed the problem.
