99 civic H22 swap
redline1219
Hey, Im swapping a 99 H22 into a 99 EX Civic. Ive never done this swap before, and I was hoping that there were any of you that could give me some tips and suggestions to make this swap easier. There is no cutting/welding needed is there? Anything could help, Thanks. Phil
You have to cut the area around the shifter to fit the cables, and maybe some light massaging in the bay (depending on the kit you use), but nothing extreme. Your two best friends are research, and planning.
I am planning on using Enjo mounts and axles for this swap for they are considderably cheeper. Has anybody dealt with JayDM.com and/or Enjo products; would I be smart by purchasing these over Hasport? I was also wondering what kind of susp set up I should use because I know that the new motor is quite a bit heavier and it will throw off the weight ratio. Would I be alright with stock susp for now? Thanks
