99 civic harness question
HybridHatch601
what wiring has to be done to make the stock 99 civic dx harness work with a b16 swap. i know the vtec, pressure, and knock. but there are a few other differences right?
Originally posted by twisted civic@Nov 8 2004, 06:53 PM
iac valve, distributor wiring has to be spliced in (color match/different plug).
[post=413933]Quoted post[/post]​
have a diagram? or a link?
ok, i found the iacv thing, but what are you saying change about the distributor?
you will need an obd2 b series dizzy, if the b16 is obd2 and has one, you'll be fine, but if it's obd1, the plugs won't fit (obd1 and obd2 plugs on the distributor and injectors are different) and you'll have to color match the wires to a set of obd2 dizzy plugs. also, you will need obd2 injectors off your old engine on the b16, unless of course the b16 is obd2 and has them already. other than that, the vtec wiring, and iacv, it's pretty straight forward.
