I just swapped in a JDM B16 with the P73 ecu and harness from a 98'. After I swapped the motor in and went in to plug the ecu there was an extra plug coming from the harness underneath the dash that could not go anywhere.
I swapped back in my 99' CX harness and realized that it is not plug and play into JDM b16, distributor plug is different, and some sensors look like they will need to be lengthened.
What should I do? Swap back in the 98' harness and get the underneath dash harness from my donor car? Get a 99-00 si harness or 99-00 ex harness? I already have the conversion harness for a OBD2B to OBD2A ecu.
Any suggestions or comments will be greatly appreciated
Thanks
Thanks
