im gonna swap a 99 b18c into my 95 del sol. i read swap article OBD 2 B18C1 into a 5th gen EX. what are they refering to IAB??
"For the IAB you will need to move A20 to A17. Since you will be using the OBD2 engine harness and an OBD1 GS-R ECU you will need to cut the black wire at the IAB plug and give it a 12V switched source. You can get this from the yel/blk wire at the injectors or the IACV. "
Is there anything I need to know as far as wireing?
thank
thank
