99 Head 94 Block?
Discussion in 'Engine Building' started by lsvtec hatch93, May 18, 2003.
  1. lsvtec hatch93
    lsvtec hatch93 Senior Member
    will the obd1 and 2 matter. im going to use the 94 intake manifold
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Come on man,WHAT head and WHAT block?
  3. lsvtec hatch93
  4. xj0hnx
    C.C.TX.
    Should go right on.
  5. lsvtec hatch93
    do you think the sensors are the same?
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    no. distributor is definately not the same
  7. pissedoffsol
    physically, it will bolt on no problem.
    the obd2 also has a pcv valve in the valve cover that the obd1 ls doesn't have. it has a breather on the back of the block instead. you might have to epoxy/close up that hole.
    as for wiring, you will need to swap some plugs, and use your obd1 ijectors/computer/dizzy/altenator.
    or, buy my spare obd1 ls head for 100+ shipping :)
  8. lsvtec hatch93
    so i just have to fill that valve cover hole and use my olds distributor and injectors?
