99 mirage de coupe, the white virgin.
Discussion in 'Other Vehicle Discussions' started by TurboMirage, Oct 25, 2009.
  1. TurboMirage
    enjoy:)
    got it yesterday. needs a few things. new sunroof seal (aftermarket), drivers corner light, drivers side mirror,a muffler (but with the stock pipe and cat it is very quiet) and the drivers side window doesnt go up. the body is in pretty decent shape, and im the 2nd owner.
    has brand new snow tires on enkei wheels, new brakes/plugs/wires/cap/rotor.
    $400.
  2. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    OMG...someone actually has.....
    ...a pink house?!?!?!?!?!
  3. eg6sir
    bout that time to get to swapping parts to make the real beater the winter beater.. lol
  4. TurboMirage
    actually the white car is stock and in great shape, and it will stay that way ;)
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Wow, so you bought a used set of enkei's with tires on the cheap and got a mirage thrown in free?
    Win.
    Do the gunmetal one up nasty. Stupid boost, crazy HP.
    Then convert the white one into a super efficient hypermiller.
    Name them yin and yang.
  6. 99sidude
    Ohio
    seriously $400? you can't get a totaled civic for that around here:g:
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    its clean actually.whats the real plans
  8. TurboMirage
    plans are to clean it up and fix the little things, drive it through the winter.
    got some new pictures -
    trunk carpets all in great shape
    fixing the stuck regulator
    interior in good shape, needs a vacuum
    the sunroof.....
    needs a headlight and corner light
    gotta straighten this fender out
  9. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    I say junk it... I hear theres a new junkyard in my garage. :D
  10. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    eww what is that crap? ;)
  11. TurboMirage
    today we pulled it in to get started on the muffler. found a rot hole in the subframe, but nothing major. going to hit it with a wire brush, some etch and rubber undercoat. the endpipe broke right before the rear control arm. going to get a coupler tomorrow to re-join the two sections together, then going to mount the flowmaster on it. should be VERY quiet... this time.
    pulled all the wiring for the sunpro tach it had on the dash. going to install the EVO cluster with this MPH gauge so i can have a real tach.
    underneath the rest of the car is decent. there is no rust inside the trunk, so woohoo!
    battery was dead again. i think the "alarm" is draining the battery, or the chintzy wiring behind the radio. have to rip the alarm out anyways since the remotes are missing. this thing also has OEM lugs and wheel locks. i'm having trouble getting the locks off i cant even get them with an impact gun. oops!
  12. TurboMirage
    got some stuffs done over the weekend.
    cleaned up all the excess wiring in the engine bay, replaced the valve cover AND gasket. no more busted ass clips. modified the intake elbow so it isnt rubbing on the brake master cylinder.
  13. BigJ
    Coming along.
    But is it just me. I don't park on my grass? And I clean up my leaves and don't have a clothes line anymore......
  14. TurboMirage
    thats not my house.
    so the car is plated and on the road as of today. put the DS mirror from the grey car as well as the headlamps in it so i can get a sticker.
    all that is left is a muffler. i love this car. its fun.
  15. phyregod
    phyregod !!YTINASNI
    Central Texas
    Nothing major?? That looks friggin horrible. You'll need to weld in new metal there or something, don't just slap some rubberized coating on it and call it a day.
  16. TurboMirage
    yeah you see its not a honda. the chassis parts are reinforced from the factory. its not a thin piece of sheet metal there. the suspension cup is solid. you cant break away any more of the metal there easily at all.
  17. double0Si
    Columbus, Ohio
    Look at the size of that hole! Youre going to have to repaint her off-white and stop calling her a virgin.
  18. TurboMirage
    so my mirage has a tramp stamp from the previous owner. its a mermaid with big tits and stars over her nipples. the vinyl is permanently grafted to the trunk of the car. we're going to get some colored sharpies and color it in ;)
    also, i piped the flowmaster 44 onto the back of the car. you cannot hear it at all.
  19. phyregod
    phyregod !!YTINASNI
    Central Texas
    How is the vinyl permanently grafted? They clear coat over it or something?
    Also, a big hole and a tramp stamp means she isn't by any means a virgin. She is playing you, man.
  20. TurboMirage
    i removed a small portion of it, and off came the clearcoat and paint too.
    we have decided to turbocharge...
    parts list -
    *E-Manage Blue with Gold conversion for datalogging
    *NGK Powerdex wideband
    *13B 3KGTVR4 turbo, fresh
    *1G CRX Si Manifold
    275cc 5G Galant injectors
    *Bosch BOV
    *2 inch charge piping, non intercooled
