99Civic Si or 99 Civic with b18c1 swap and disc conversion
Discussion in 'HYBRID -> EG-EK / DC' started by porsche911s4u, Mar 7, 2006.
  1. porsche911s4u
    porsche911s4u Junior Member
    hey guys,
    I am in the process of replacing my daily driver sunfire with a civic. I am looking into my options and i am stuck between the 99 civic si and civic ex with b18c1 swap and rear disc brake conversion. My plans are to eventually build the engine and turbo it. I am eventually looking for around 300 horsepower. Would I be better off buying a 99 civic si? or a cheaper Ex and just do the swap? Is 300 hp a more difficultly attainted number on a b16a2 comapred to a b18c1? all help is greatly appreciated. Thanks, Jason
  2. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    Both engines are very similar, would be easier to build a B18 to 300 horsepower since the displacement is greater, but it will only take slightly less, weigh your options? cost and ease of doing the swap. it will cost $3-4k to put a GSr engine in a car even if you have everything you need to do the swap. It is up to you.
    IMHO; having a swapped car is cooler than buying an SI, but if you find it is going to cost more to put that engine in then just get the SI
  3. jamesA
    Check out the cost difference from buying a Civic LX vs buying a Civic Si.
    I'll bet the price difference between the two would allow you to buy a swap for the LX... and it'll be cheaper on insurance as well.
  4. capone9399
    capone9399 Senior Member
    Scranton
    :withstupid:
    Yeah your much better off buying a lower trim if your gunna build it up.Start with slow and make it all go.
