a couple questions
96prelude
have an 88 crx si with a b16a1 in it. i need new shifter bushings because there is alot of slop in the shifter. i've seen the diy write-ups but i need to know what to buy. would i but the bushings made for the CRX or bushings to match up with the engine / trans?
next question. through my research i have found that the rear suspension set up is diff in the 88 as opposed to the 89-91. i have a friend that has a rear disk set up from a DA integra, will that work with aftermarket coilovers made for the 89-91? also are there any good coilover set-ups that will fit the 88 without modification?
please don't tell me to search. i searched already.
thanks in advance for your help.
buy the bushings for the motor,,get energy suspension,they are good qualityand fitment..
as for your suspension question,,,
the springs and struts are virtually the same between all civics and integras(ecluding the type-r)
so yes the integra rear disks wil work with the springs for the civic
