a D axle is a D axle, correct?
seanjuan
I have a set of Dseries axle's in my garage from my old D15 (92 vintage) and a friend of mine needs new axles on her 96 EX
I am 99% sure that the axles are the same but figured it can't hurt to run it by you guys just to make sure
thanks
Quoted post[/post]]
thanks
Not sure if those will work, but all "d" axles were not created equal. There are several different variations.
*edit* I'd be willing to bet that it wouldn't work, because, if I am guessing correctly, the 92 didn't have abs (Wasn't standard, was an option) and the 96 does. making the axle different.
No, i used 95 EX axles on my Girl's 97 Ex, it will work.
Same part number too, as long as neither car has ABS.
crap, I forgot about the ABS deal
so since my axles are non-abs that means they don't have the ring on them for the abs speed sensor
and my friends car does have abs so they won't work.... oh well, at least I realized it now before I pulled her axles out
thanks guys
Quoted post[/post]]
thanks guys
No Problem. :wink:
