A few mini-me questions
Discussion in 'HYBRID -> ED-EF / DA' started by 1991DxRex, May 27, 2011.
  1. 1991DxRex
    1991DxRex New Member
    Ok I am about to perform a mini me with an obd1 conversion on my 91 crx in a few weeks and i had a few questions before i started which i couldn't find a definite answer for in my research. Oh and the head ect.... is a d16z6
    1. Will i need a fuel pressure regulator from a 92-95 civic ex?
    2. Also i read somewhere that the dpfi uses lower fuel pressure so would i need to get a fuel pump from a 92-95 civic ex?
    3. Also someone before me did a messed up swap and put in a d16y7 block and head with the d15b2 intake mani distributor ecu ect... but i was wondering if the marks on the crank pully to set the engine timing would be the same as a d16z6
    4. I also found a cheap DC sports header in my local Craigslist for a 92-95 civic but i was not shure whether i could use this exhaust manifold in an ef chassis
    if anyone could help me with these few questions it would be much appreciated and thank you for your time
