A few parts question
Discussion in 'Civic and del Sol - EG and EK' started by Periculum, Aug 29, 2009.
  1. Periculum
    Periculum Senior Member
    Martinez, GA
    I'm looking for a few things for a friends Del Sol. I don't know the EG chassis too well so I want to make sure the parts fit.
    I'm looking for the lug nut covers for the Del Sol rim. They look like they are the same size as the ones on the civics of the same year, but I'm not 100percent sure on that. Can anyone confirm?
    I'm also wondering if the power window/locks control panel on the driver side door would match up with the Del Sol set. I imagine if it did, it would have one extra window switch. The Del Sol's controls are pretty bashed up, so it would still be an upgrade.
    And a technical question: The outside door handle doesn't open the door but the inside door handle does. I've only been inside a car door once or twice. Isn't there a bar that goes to the outside handle? I suspect that may have been knocked loose. It also appears someone tried to pick the lock in the past, so it may have just been completely broken.
    Thanks for the answers, as always!
  2. BrutalB83
    Rochester Hills, MI
    Lug nut covers? I'm not sure that I know what you mean...
  3. Periculum
    Martinez, GA
    Sorry, the wheel covers that have the honda symbol on them. Covers up the lug nuts to make the rim look nicer. Couldn't think of a good word for them.
  4. SCCAEK21
    SCCAEK21 New Member
    TX
    As long as there the same generation 95-98% of the parts should swap over if Im not mistaken
  5. BrutalB83
    Rochester Hills, MI
    Oh, you mean the hub caps? They cover up the hub, not the lug nuts. The lug nuts go on over the hub caps...
  6. Periculum
    Martinez, GA
    I was thinking of what is part number 8 in this picture. I can't seem to pull up the part number for any of the other center caps on any other models I think might be usable.
    Honda Automotive Parts
