Supergreen95EX-GSR
OK guys here goes. I have a 95 EG with the D16Z6 and I floated the valves on the SOHC. So I just got a JDM B18C GSR motor. What do I need to be aware of when I am doin this swap? I have a new GSR throttle cable, the rear teg motor mount bracket, and axles, halfshaft, LSD, P72 ecu etc. The GSR motor is OBD I just like my SOHC and I am wondering if I need to be aware of anything suprising with this swap? I have a new clutch and flywheel already but what about the wiring issues? I have heard you have to add a knock sensor but I have no idea where it would go. Also I heard something about lengthening some IAT wires or something. Sorry for the long post but I want to be totally prepared for this before I start. Any help you could give will be appeciated. Also does anyone know of any good comprehensive websites or books with detailed instructions on this swap? Thanks for the help! Sean
