MinuteRice
i have a 91 civic with a zc swap that needs to be timed, but i dont have the lower timing belt cover with the timing marks on it. Will a cover from a 89 integra DOHC 1.6 GS work.
Also i found a d16z6 for cheap and want to put it in for 93 civic sadan. the sadan is an auto and the z6 is a stick, what wiring is needed to make the z6 ecu work with the automatic tranny. the car needs to be done before winter so i have something to drive
