sleeper_crx88
Member
ok im not sure if anyone runs into this problem often or not but i did. i made my own jumper harness, and wired up the motor...(95 gsr into 88 crx si) problem is; my car is throwing code(s) but i dont know how to access them. i know that in obd1 civics and integras theres a harness by the ecu that has two wires that you have to connect to "jumpstart" the ecu to find out what code the ecu is throwing. but now that the b18c1 engine is in my crx i dont know how to access the codes...theres probably an easy solution to this but i dont see it. can anyone help me with this so i can fix the problems on my car?
